Honda CX500 and GL500 Forum: "turbo" kicks in at 7k rpm on a non turbo... - Honda CX500 and GL500 Forum
Jump to content
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
"turbo" kicks in at 7k rpm on a non turbo... carb or cdi issues?....
#31 User is offline   Shep
  • Cogito ergo ride
  • PipPipPipPip
  • Group: Members
  • LocationHull:Yorkshire 2X 1980 CX500A
Posted 10 May 2012 - 04:16 AM
Backfires can be caused by an exhaust leak?
Also Air-cut off valves in the carbs.
0
#32 User is offline   CX500CUSTOM
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationWalla Walla, Washington
Posted 11 May 2012 - 08:16 AM
Ok, it is a little hard starting. Hesitates and sputters a little below 3k. I am running premium and some seafoam in the tank this round to see if anything improves. I will check for exhaust leaks and inspect the air cutoff valves. Thanks for sticking with me Shep.
1980 CX500 CUSTOM.
"Be kinder than necessary, for you never know the battle that others are fighting˝
0
#33 User is offline   Shep
  • Cogito ergo ride
  • PipPipPipPip
  • Group: Members
Posted 11 May 2012 - 08:45 AM
No problem.I like people to get their bikes as good and smooth as mine are just so they can appreciate how good they can be :)
I've just finished some more info that may help,
http://www.pdsrecord...0/CarbMain.html
2
#34 User is offline   FADM Stern GNSF
  • Metal Head
  • PipPipPipPip
  • Group: Members
  • LocationToronto, Ontario, Canada
Posted 11 May 2012 - 10:51 AM
Well, make take a lot of guessing, but so far the people here have a really high success rate :)
Does it backfire when idling, or only when letting off the throttle ? If you have an exhaust leak it can cause this sort of problem.
1982 CX500C
1979 GL1000
CX WIKI Pages
Link to Larry's Carb Book
0
#35 User is offline   Loose canon dinowilliesII
  • Grand Nagus
  • PipPipPipPip
  • Group: Members
  • LocationCanon City, Colorado
Posted 11 May 2012 - 12:00 PM
View PostBradjo9, on 30 April 2012 - 08:08 PM, said:
Hmm I seem to have the same "turbo" feeling after 7k, thought it was supposed to be that way. So I should look at the carb pistons huh?
Hmmm, mine comes on the greased lightning at 7000RPM too. I have'nt located the turbo yet though. wonder if there are any aftermarket turbo's available for the 500. Happy riding, dinowilliesII
0
#36 User is offline   turboExperience
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationMiddle Indiana
Posted 12 May 2012 - 07:31 PM
View PostCX500CUSTOM, on 09 May 2012 - 09:43 PM, said:
update, I have replaced the right coil, and the battery. I cleaned out the carbs, removed the jets, blown out the carbs with cleaner and air, and tuned and synced the carbs. It runs better, but it started puttering and backfiring a little bit....need a pro on this one please.
I can't claim to be a pro, but it sounds like the valve timing is off. Can't figger out how, though, unless somebody replaced the chain and got it a tooth off.
Of course it wouldn't correct itself, either.
More thought needed, as soon as brain cells are available. I'm in the middle of a CX500 turbo "refresh".
'82 CX-500 Turbo
'94 VT-600CD
'82 CX-500 Turbo #000541(sold)
'80 GL-1100 (sold)
'79 CX-500 Deluxe (sold)
0
#37 User is offline   CX500CUSTOM
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 18 May 2012 - 10:05 AM
Found my coil mounting bolts loose. Will re tighten and update.
1980 CX500 CUSTOM.
0
#38 User is offline   CX500CUSTOM
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 19 May 2012 - 09:57 PM
ok, so I removed the coils, sanded the ground contacts with 400, sanded the mounting brackets, sanded the bolts and nuts, sanded the frame where the bracket mounts, and put everything back together. I used blue locktite on the nuts. I took the bike for a ride and it ran great, then once fully warmed up it started to hesitate around 3k until 5k or 6k. Then, again the "turbo" kicks in. Although not as dramatic this time. I took it downtown to fill up the tank, after filling up it would not start. I cranked it and gave it a little throttle and then POW, it backfired. I gave it about 40% choke and it started right up. Once home i noticed that at idle it stumbles a little. So, i pulled the left spark plug wire and the stumble disappeared. I then plugged it back in and there the stumble was again. I pulled the right spark plug wire and the bike dies....So, logically that would tell me that the left cylinder is stumbling. Everything checks out on the cdi and the resistor caps have been rebuilt, new spark plugs....I have switched the coils and the problem persists. Any ideas anyone? I am stumped!
1980 CX500 CUSTOM.
0
#39 User is offline   CX500CUSTOM
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 20 May 2012 - 12:03 PM
Could this be the low speed pulsar on the left side? A link to check this out would be awesome! :D
1980 CX500 CUSTOM.
0
#40 User is offline   CX500CUSTOM
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 24 May 2012 - 12:49 AM
Replaced my rectifier. Will report back. So far so good
1980 CX500 CUSTOM.
0
#41 User is offline   CX Rancher
  • Member
  • PipPip
  • Group: Members
  • LocationOhio
Posted 11 June 2012 - 09:28 PM
Yikes ! Primary ignition>? You may need a donor engine for parts. I think the Honda manual may have tests to follow. At least you can say that you are a carb-vet. I was wondering how the transition from lo to hi speed timing occured. It does occur HOT only? so perhaps a primary coil or pick-up shorts when hot.
Luv a Maggot with a Twist
1978 CX500 comfy trusty maggy
1982 SWGLi500
1982 CX500T
1982 CX500T (show quality)
1983 SWGLi650
1983 CX650T
1983 CX650C loud and naked
1983 CX650C (donor)
1976 GL1000
1984 VF500C (sold)
2002 XR50 (sold)
2006 XV250V under 50mph = 85mpg with mild sprocket mod 16/40
Ready for another ?
0
#42 User is offline   Mava
  • PipPipPipPip
  • Group: Members
  • LocationVirginia, USA
Posted 27 June 2012 - 09:59 AM
This post has been edited by Mava: 27 June 2012 - 09:56 PM
1982 CX500 Custom
2008 Kawasaki KLR650
Previous ride:
1982 Kawasaki KZ305 CSR
0
Share this topic:
  • (2 Pages)
  • 1
  • 2
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
