Honda CX500 and GL500 Forum: Gl500 + Hondaline faring, need different handlebar - Honda CX500 and GL500 Forum
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   prairie
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationEast Central Iowa
Posted 06 May 2012 - 04:58 PM
The stock bar had way to much pullback for me to be comfortable, a free one from a 80 CX500 was some better but not great and was rusty. Now I am trying a dirtbike bar, clears the tank but the clutch lever hits the fairing at right lock and it's a bit wider than I want. Bobbing the lever would fix that however this bar is a bit "straighter" than I'm comfortable with, the others rotated my wrists too far the other way. Why is it so hard to find a bar that will give me a UJM position? The stock one reminded me of a garden rototiller and made riding on my gravel road a fright. Not trying to make this thing into a pseudo-sportbike, just need to feel in control instead of along for the ride.
Recommendations welcome..............
I'm also planing a set of foot peg mounts that move those back bout 3 inches.
79 CX500
82 GL500
89 Hawk GT
73 CB350G
Iowa
0
#2 User is offline   crow
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationMalone, NY
Posted 06 May 2012 - 07:44 PM
Have you tried Norman Hyde "M" bars? I put them on my Bonneville, as I hated the look of the US spec pullback/ramshorn or whatever they call them.
Now, on my CX500 frankencafe, I used a set of honda SL 125 bars from the 71-73 models..They cleared the deluxe tank I used,and have a bar you can shorten some, and perfect pullback..cheap on e-bay Sl125 site.
John (crow)
1980 Cx500 custom
0
#3 User is offline   prairie
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 06 May 2012 - 10:15 PM
Thanks for the tip, will give them a good hard look.
79 CX500
82 GL500
89 Hawk GT
73 CB350G
Iowa
0
#4 User is offline   Blindstitch
  • Avian Threat
  • PipPipPipPip
  • Group: Members
  • LocationGreenfield Wisconsin
Posted 06 May 2012 - 11:36 PM
There is also the option of getting bars that you think will work then cutting them where they go vertical. Then insert a pipe so you can turn/rotate the angle of the handlebars and then have it rewelded in the better position. Shouldn't have to be like this but it does work as a last resort to just a simple bolt on.
1968 Honda CT90 Trail-Yellow Monster project
1979 Honda CX500 Supertanker 72,000 miles and growing.
1983 Honda Gl650I Falcon-killer 63,000 miles
Pictures of my bikes Past and Present.
Posted Image
Quick Reference Sheps Forum Supertanker Build Back up Info Drop IO Backup ⇒ Free Factory Service Manuals ⇐
Donate to the Forum
0
#5 User is offline   Randall-in-Mpls
  • A bad influence on my children
  • PipPipPipPip
  • Group: Members
  • LocationNE Minneapolis, MN
Posted 07 May 2012 - 12:27 AM
I've heard that contemporary Goldwings that had flatter bars. They used the same fairing, so there shouldn't be any interference. I can't verify this personally, but it's an avenue to explore.
R
1978 CX500 Standard - The Black Maggot -> Green Grub, Red Grub, Yellow Grub???
Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
Mods: Daytona-style fork brace, fork boots, air fork kit, Spitfire windshield, '81 radiator and trim,
Hondaline engine guards
, Ignitech CDI, blade fuse, Goldwing air shocks.
1981 GL500 Basket case -> AdvWing (Dual-sport conversion in progress)
Posted Image
0
#6 User is offline   prairie
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 07 May 2012 - 05:00 PM
Well that project is over for a while.
Fly brand off road bar($23), as in one with the little brace bar is mounted up and looking more promising than before, did remove the roll-pad. This one has 4 inches of rise and much less would have you dragging you knuckles on the storage box lids, that Hondaline faring complicates things a bit. Had to cut the flanges off the new grips but thats okay, just sanded down the rough spots where my hands will rub on the switchgear. Used safety wire to snug up the NEP throttle clamp, no flop and less drag. Gonna look into fitting one of those dog-leg clutch levers as that should fix my clearance problems.
Will buy a M bar when funds allow for either the CX or a CB350G project bike.
Thanks to all who posted, at this point I don't believe this is the best bar, even for me but a big improvement all the same. Now to mocking up those foot peg mounts!
79 CX500
82 GL500
89 Hawk GT
73 CB350G
Iowa
0
#7 User is offline   romzrx
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationLong Island, NY
Posted 07 May 2012 - 05:47 PM
try the ZRX bars they are low rise and pull back few inches similar to Daytona bars.
0
#8 User is offline   prairie
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 10 May 2012 - 10:40 PM
Well I got ahead of myself, needed to shorten some cables, clutch by 6 1/2 inches, wish I had one of those ends that are curved at the top. Anyway cleaned cable and housing then lubed with high grade bicycle grease, cable moves easier than a new one. Made the replacement end slug out of O2 tool steel rod I have around and brazed it to the cable, reused ferrule and plastic that goes around slug.
Gonna hold off on the throttle cables till the next rainy spell.
79 CX500
82 GL500
89 Hawk GT
73 CB350G
Iowa
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
