Honda CX500 and GL500 Forum: starting after 10 days - Honda CX500 and GL500 Forum
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   Buckklier
  • Newbie
  • Pip
  • Group: Members
Posted 14 May 2012 - 09:24 PM
I have a 82 GL500 that will start every day after I ride it, but park it for 10 days - 2 weeks and it will start hard and only run on one clyinder for about 5 -10 seconds, then it will suddenly run on both clyinders and run fine, with no problems until it sits for 10 plus days, and have the same trouble, all over again. Anybody have the same problem, or any ideas?? :huh:
0
#2 User is offline   Hanibel
  • Member
  • PipPip
  • Group: Members
  • LocationHomewood, IL
Posted 14 May 2012 - 09:50 PM
I had the same problem. Shut it down, turned off the fuel and it sat for a week. Would not start. Was in a hurry and forgot to shut off the fuel. Next day it started on the first try. So for me it appears to be a fuel evaporation problem.
So now if it has to sit for an extended period of time I go out a little early, turn on the fuel, finish my coffee and she fires right up
Dennis "Hanibel" Matl
1979 CX500C
0
#3 User is offline   ramprat06
  • Happy Herriot Helperton, aka Some Numpty
  • PipPipPipPip
  • Group: Members
  • LocationVancouver, WA USA
Posted 14 May 2012 - 10:20 PM
This is not an uncommon issue. It is due to the carb bowls evaporating the fuel......assuming there are no leaks. It's common to many of the GL's and CX's. Some folks never seem to have a problem, and I've seen some mentions of ways to avoid it, but I don't have them to hand. Others will surely chime in. I'd not be concerned if you are able to get the bike fired up in relatively short order.
Joel in the Couve
May the myriad of wheels in your head, keep the two wheels between your legs rubber side down.
Age 58. G-Loria 82 500 Silverwing Interstate, 13k, and my honey's 88 Shadow VT1100
CLICK ME FOR MY STORY>> Posted Image Posted Image
WIKI LINK for all the tech stuff
Picture posting help
0
#4 User is offline   Showmedude
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationSoCal Desert - Antelope Valley
Posted 15 May 2012 - 12:12 AM
If the vacuum-driven fuel petcock is functioning on the GLs, just turning the gas on does not let it flow to the carbs. Cylinder vacuum from the right side carb (while cranking or running) opens a diaphragm in the petcock allowing gas to get to the float valves, which will let it go into the bowls if they aren't full. I crank mine for a couple of seconds, twist the throttle to activate the accelerator pump (maybe helps, hard to tell) then keep on cranking till it fires up. On mine, it's the right side that is slow to fire off - I think because I keep the bike on the side stand and it takes a little longer for that carb to fill.
Dude
'82 GL500I, 37K miles, acquired 5-23-2010
GL650I Project*, 33K miles, acquired 9-3-10
GL650I 69K miles, acquired 1-7-11 (the last one, I think!)
* Frame, engine, and tires together, the rest in 6 boxes.
Just happy to be here!
0
#5 User is offline   bandit
  • quechito
  • PipPipPipPip
  • Group: Members
  • Locationespania
Posted 15 May 2012 - 01:50 AM
only from memory,Abes posted on the old forum,that after 2 weeks sitting the amount of evaporation is virtually zero.he conduct tests to show that was the case. <_<
and if the OP,s bike only runs on one pot,than evaporation only is only in one carb...i doubt it. <_<
but my theory.
high fuel levels in the bowls will also cause hard starting.so,bearing in mind,not all bikes have this issue.it could be that,if the petcock does not 100% shut off fuel,then over a period of time weeping fuel via the fvn could raise the level in the left carb.
my thoughts for the day.
B)
1981 GL500 , UK MODEL,needing a bit of tender loving care
1982 GL500 , UK MODEL,my daily ride.
Posted Image
Andalucia,in the south of spain
aka spanish bandit
0
#6 User is offline   baxlin
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationTring, UK
Posted 15 May 2012 - 02:03 AM
Mine doesn't have the petcock, just an on/off tap,which I leave on all the time, and I fitted an inline filter. The engine's often not started for a couple of weeks as it's not my daily drive, and it starts first time no problems.
I do however have a trickle charger which is hooked up every time it's parked in my garage, so I know the battery's full and ready to go.
HTH
Malcolm
Just an opinion, please don't shoot me if it doesn't coincide with yours............
0
#7 User is offline   muzza
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationNew Zealand
Posted 15 May 2012 - 03:36 AM
I bet the problem is the crappy fuel we have these days. Get yourself one of those long electrical screwdrivers and drain the fuel bowls for 30 seconds or so so that when you turn the drains off the bowls are full of fresh gas from the gas tank.The fuel in your bowls has evaporated some of the volatile elements out of it and it is hard to ignite.
I have to do this with both my CX's after any more than about 5 days standing. Drain the bowls and they fire up pretty readily.
In New Zealand
1979 CX500 cafe - it lives!
1983 CX650ED
1983 CX650 uber modernist cafe project bike
0
#8 User is offline   Shep
  • Cogito ergo ride
  • PipPipPipPip
  • Group: Members
  • LocationHull:Yorkshire 2X 1980 CX500A
Posted 15 May 2012 - 05:01 AM
Click here,
http://globalcxglvtw....php?f=10&t=823
HTH :)
0
#9 User is offline   HotFoot
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationSW Lower Michigan, USA
Posted 15 May 2012 - 07:17 AM
Same symptoms experienced here. I run a fuel filter, tank is lined (POR15) and carbs are clean/maintained. Ignition system is kept up properly.
I find it helpful to completely drain the tank several times a year especially upon the springtime awakening. This includes removal and shaking the tank while upside down (cap removed) to get that last quart or so of unuseable fuel out. What comes out looks like a urine sample and smells a bit like paint thinner/mineral spirits.
An oil/fuel supplier about 10 miles away has real non-ethanol fuel which I am going to try when my current stash of gas-staion fuel in cans is gone. I'm convinced the fuel we get is inferior to what we used to get years ago. I don't often fill up my bike at a service station so every can I fill gets the Sta-Bil treatment as soon as I get it home. I will also run a bit of Sea-Foam, Marvel Mystery Oil, Lucas etc. Depends on what's on sale or what I have available at the time.
Hoppy
1980 CX500D (Roadworthy Fun)
1979 CX500C (Stagnant Project)
Growing SHOP (Shameful Hoard of Parts)
Pacing Counts As Exercise
0
#10 User is offline   murrayf
  • Grand Nagus
  • PipPipPipPip
  • Group: Members
  • LocationLexington NC
Posted 15 May 2012 - 07:40 AM
ditch the vacuum petcock and it will go away here is a 20$ solution
http://www.ebay.com/...270dc1e&vxp=mtr
and the problem gets worse in hot weather and happens faster
GET AN OIL FILTER ADAPTER
Current Bikes
1983 GL650 naked
1983 GL650 full dress
1981 gl500 cafe 650 motor dual mikunis
3 1978 CX500 WHAT????? i like them
1980 cx500 deluxe test bed bike
1978 cx500 BIG 650 motor dual mikunis
1980 Deluxe dont know what it will be yet?
1977 Gl1000 dual 38 Mikuni carbs New Daily Rider
and some others
0
#11 User is offline   FADM Stern GNSF
  • Metal Head
  • PipPipPipPip
  • Group: Members
  • LocationToronto, Ontario, Canada
Posted 15 May 2012 - 08:06 AM
Well, I have experienced the same problem with mine, one push after an idle day, but 2 weeks and it takes a few cranks. While there will be some evaporation from the carbs, I tend to side with bandit on this one, the evaporation is actually very small due to the diameter and length of the drain tubes, which only shows a very small surface area to the atmosphere. I actually believe is gas evaproation from the carb body and intake spacer that is the problem, not out of the float bowls. With the bike sitting, the gas in this area (and it will be there) is pretty well isolated from the outside (carb plates, air box and filter), and will probabaly take a few days for it to evaporate away.
I also have a vacuum petcock (and will always keep it, I love this thing) and have seen after a week or so I have to crank a few times to get it to start. I did find that the problem of one cylinder starting late improved a lot since I ballanced the carbs.
1982 CX500C
1979 GL1000
CX WIKI Pages
Link to Larry's Carb Book
0
#12 User is offline   bandit
  • quechito
  • PipPipPipPip
  • Group: Members
  • Locationespania
Posted 15 May 2012 - 08:30 AM
B)
surly someone from the old forum can remember abes post. <_<
general information.
low fuel in a hot tank will blow the fnv,s open filling the bowl and shedding the fuel down to the floor.
yes my tank is vented
yes it was parked at the time,i was sat in a bar and watched it happen. :(
B)
Posted Image
aka spanish bandit
0
#13 User is offline   White Knight
  • Advanced Member
  • PipPipPip
  • Group: Members
  • LocationBay of Islands,New Zealand
Posted 15 May 2012 - 04:36 PM
This problem has existed with CX engines for the past 30 years so maybe we have to live with it--Drain carbs,tip drained fuel back into tank (i'm a tight bugger) and hit the starter-vroom.-WK
CX400 Euro 1986 in mint condition
CX500 Euro 1986 fully restored from wreck
!970 Honda S90 Sport
0
#14 User is offline   PDC-500B
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Location'twixt Gloucester and Bristol, in little ol' England.
Posted 15 May 2012 - 05:11 PM
View PostWhite Knight, on 15 May 2012 - 09:36 PM, said:
This problem has existed with CX engines for the past 30 years so maybe we have to live with it -WK
Absolutely. First time I ever encountered difficulty starting my CX500 was back in 1981, when it was new, and I was going to take it in for its first (600 mile) service. I hadn't used it for over a week, and it just didn't want to start :angry: . Being new to me, and not knowing of this CX habit of non-starting after a short lay-up, I ended up flooding it in the process :rolleyes: .
What I've done in more recent years, if it's not been used for a while, instead of churning it on the starter to no avail (and it doesn't do the battery or starter a lot of good), is to first turn on the (non vacuum) fuel tap. Then I get the bike out of garage, have a quick look over it, maybe check oil level, lights, tyre pressures etc, get togged up, helmet and gloves on etc, and by the time I go to start it, it then fires up almost instantly, with choke. If it's used daily, it fires up no problem straight away :D .
1981 CX500B (England model) owned from new
0
#15 User is offline   Timothy_d
  • qwertyuiop
  • PipPipPipPip
  • Group: Members
  • LocationSebastopol, CA
Posted 15 May 2012 - 05:18 PM
When my bikes sit for a couple of weeks, I usually turn the kill switch to the off position, hit the thumb kicker for about three to five seconds, then flip the kill switch with my thumb while it's still cranking. Works pretty well for cx650's.
Currently own, '78 CX500, '82 CX500T, '83 CX650E, '08 DR-Z400 SM
Previously owned: CX500T (x3), CX650T, '81 CX500D (x2)
0
#16 User is offline   muzza
  • Advanced Member
  • PipPipPip
  • Group: Members
Posted 16 May 2012 - 02:59 AM
Might just be the shit fuel we have here in New Zealand . The stuff definately goes off in the fuel bowls after a week or so. Had a mate whose father owned a succession of CX's from new in Australia and he had a ritual of draining the fuel bowls if the bike hadnt run for more than a couple of days . That and always carrying spare brand new plugs in case it really packed a wobbly ....
In New Zealand
1983 CX650ED
0
#17 User is offline   Knute
  • Almost Skilled
  • PipPipPipPip
  • Group: Members
  • LocationAnderson, SC
Posted 16 May 2012 - 07:05 AM
ahhhh.......thought
Are you starting the bike on the side stand?
The floats may be in a "bind" due to the fuel level in the bowls being skewed relative to the motion of the floats. The right carb will be high compared to the left carb. Fluid will move to the lowest level. The right carb could be fill the left carb thru the cross over tube.
Mine was out of commision for 2 weeks while the replacement coils arrived and my installation. Sat on the center stand the entire time. No trouble starting.
This may not be an evaporation or a fuel quality issue. Could be gravity.
Just a thought.
1981 CX500C
0
#18 User is offline   boulder cx500
  • Grand Nagus
  • PipPipPipPip
  • Group: Members
  • LocationBoulder CO
Posted 16 May 2012 - 08:44 AM
You have a vacuum petcock. Fuel evaporates depending on ambient temperature. After prolonged sitting, put the kill switch off, leave the throttle closed and choke off (maximizes vacuum) and crank the engine for 3-4 seconds three times. Turn the kill switch to on, choke and start.
0
#19 User is offline   Eurovee
  • Grand Nagus
  • PipPipPipPip
  • Group: Members
  • LocationEngland
Posted 16 May 2012 - 11:55 AM
Approach motorcycle from the left - NOT right.
Turn ignition switch on - off - on - off. Do this twice. One time standing on left leg only, other time right leg only.
Poke index finger (of either hand) into exhaust pipe and pull out quickly three times each side - six times if 2 into 1` fitted.
Turn fuel tap on - do not touch fuel tap directly but hold with a leaf from a ungabe mungabbo tree. If no ungabe mungabbo trees are availabe a rubber plant will do.
Pull choke up and place a handcrafted wooden peg from an authentic Romanian gypsy underneath the knob to prevent it from returning.
Place a shot glass of a single malt Islay whisky (Bourbon may work at a pinch..) directly on top of the fuel tank filler.
Spit on both hands and operate ignition switch and throttle while spinning the rear wheel round (in the normal direction of rotation when travelling forward) with your right leg - do not remove hands from motorcycle until engine starts, do not let rear wheel speed fall below approx 17.6 mph.
If engine fails to start or either hand is loosened from handlebars the process from the beginning will have to be repeated until successful.
If bike starts, ride away.
If it doesn`t, drink the whisky.
Works for me..
0
#20 User is offline   ramprat06
  • PipPipPipPip
  • Group: Members
Posted 20 May 2012 - 06:15 PM
Works for me..
Sounds quite like an approach to married life...... B)
0
#21 User is offline   fibonacci
  • Triple 0 - Licensed to Kibitz
  • PipPipPipPip
  • Group: Members
  • LocationTampa, FL
Posted 20 May 2012 - 07:21 PM
That was a good read Eurovee. :D
OP - all of this discussion and no one has mentioned the obvious - ride it every day. Works for me. :D
Fib
Wiki link
'83 GL650 ("Beatrix) Kiddo"
Who is John Galt?
"Better to remain silent and be thought a fool than to open your mouth and remove all doubt"
"Don't worry about it, I'll worry about it - I'm gonna be up anyway" Joe Walsh
Posted Image
0
#22 User is offline   Billrod
  • Grand Nagus
  • PipPipPipPip
  • Group: Members
  • LocationRichton Park, Illinois
Posted 20 May 2012 - 09:45 PM
Let me confuse this issue even more. I have the same problem with my GL500. My current starting drill, which I have decided on after reading all starting posts, is to pull the choke on full, twist the throttle 5 to 10 times (depending on how long it has been sitting). It usually starts on one cylinder (not sure which one) and a few seconds later is running on both. I ease the choke in about 1/2 way and head down my gravel road and push the choke in all the way by the time I get to the end.
I have the vacuum petcock and never turn it off and only move it to reserve when I forget to fill-up by not watching the trip meter. I know one of the carbs has an accelerator pump and assume that is why pumping the throttle works. I guess my question is if the gas evaporates from the bowl, where does the accelerator pump get the gas that it seems to use to start my bike. I have no idea but it sure works for me. Billrod
1982 Naked GL500
73 years old - April 1939
If you can't fix it with a hammer, you have an electrical problem.
0
#23 User is offline   Shep
  • Cogito ergo ride
  • PipPipPipPip
  • Group: Members
Posted 21 May 2012 - 06:10 AM
I've found undoing the left hand side drains screw for a few seconds and or a quick spray of WD40/Carb brake cleaner into the Air-filter if needed usually cures most time-left starting so long as the battery is kept well charged/serviced.I would imagine AGM/Gel batteries lose less current when left.
Click here
http://www.pdsrecord...0/CarbMain.html
HTH :)
0
#24 User is offline   FADM Stern GNSF
  • Metal Head
  • PipPipPipPip
  • Group: Members
Posted 21 May 2012 - 09:26 AM
Billrod, I used to do the exact proceedure you use as it worked well. I really dont think its a matter of the bowls empting out, just the gas that normally is present in the carb body/intake manifold/cylinder evaporates. When starting the engine, it takes a few revolutions before the gas gets pulled from the bowls up into the bodies and into the cylinders. If you rode it less than a day ago, there is still gas there and thats why it starts quick.
As for the one cylinder starting, mine is a lot better now that the carbs are synced, and now it starts on both cylinders every time.
1982 CX500C
1979 GL1000
CX WIKI Pages
0
#25 User is offline   Blue Fox
  • Grand Nagus
  • PipPipPipPip
  • Group: Members
  • LocationColumbia, MO
Posted 21 May 2012 - 10:53 AM
I'm tending to agree with FADM on this one too. For the guys who "need to know", just drain and measure the amount of fuel you can drain right after a ride. Then the next time, wait a week to do it, and compare. I'm guessing they will be close to the same.
1983 GL650I, 1980 CX500, 1979 CX500, 1982 GL500I, 1978 CB550, 1974 CB350F, 1973 CT90
Need information? Try our new Wiki site: http://cxgl.wikispaces.com/
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
