shaft drive rubber gaiter replacement suggestion
#1
Posted 23 June 2012 - 09:02 AM
1983 Cx500 Rolling Chassis (Summer Project)
#2
Posted 23 June 2012 - 09:32 AM
My bike runs with no gaiter so do not worry about that. Just unbolt the shaft from the output shaft , slide it out of the way , prise out the old seal and gently tap in the new. Re-assembly is a reversal of above.
If you just use inner tube and glue you would allow the swing arm , where the drive shaft fits in , to fill with engine oil. Consequently the engine would run a bit low on oil and could possibly seize. Best case would be the diff unit would piss out oil all over the rear end of bike ( not a good idea )
http://www.cb500club.net/forum
http://www.classicgoldwings.com
http://www.classicgo...m/forum/portal.
http://on-yer-bike.forumsmotion.com/
http://honda-superdr....com/index.cgi?
http://www.goldwingf...orums/index.php
http://www.ngwclub.com/
1983 GL1100AD
1980 CX500
1980 CB400N Superdream
#3
Posted 23 June 2012 - 10:01 AM
as previously stated, replace the drive-shaft seal.
Carefully!!!!!!!!!!!!!!
1978 CX500 (Not Running Yet)
1979 CX500C (Marshall's bike)
1978 CX500, Billy's wreck
#4
Posted 23 June 2012 - 10:28 AM
#5
Posted 23 June 2012 - 10:32 AM
Current Bikes
1983 GL650 naked
1983 GL650 full dress
1981 gl500 cafe 650 motor dual mikunis
3 1978 CX500 WHAT????? i like them
1980 cx500 deluxe test bed bike
1978 cx500 BIG 650 motor dual mikunis
1980 Deluxe dont know what it will be yet?
1977 Gl1000 dual 38 Mikuni carbs New Daily Rider
and some others
#6
Posted 23 June 2012 - 12:47 PM
'83 GL650 ("Beatrix) Kiddo"
Who is John Galt?
"Better to remain silent and be thought a fool than to open your mouth and remove all doubt"
"Don't worry about it, I'll worry about it - I'm gonna be up anyway" Joe Walsh
#7
Posted 23 June 2012 - 07:16 PM
http://www.ebay.com/...t+boot&_sacat=0
I wouldn't run without one as road grime and crap can ruin the U/J,which is a bigger job.Why take the risk for such a small cost?
Also and of course the good old,"Shoe Goo",
http://www.ebay.com/...oo&rt=nc&_dmd=1
http://globalcxglvtw...h.net/index.php
http://www.pdsrecord...0%28Shep%29.htm
Original Music
http://www.reverbnat...in#/pauldouglas
#8
Posted 23 June 2012 - 08:06 PM
Fib
Who is John Galt?
#9
Posted 27 June 2012 - 07:26 AM
#10
Posted 27 June 2012 - 07:43 AM
#11
Posted 27 June 2012 - 09:46 AM
I suggest that you first soften the boot with repeated applications of ArmourAll over a few days or weeks. Then, thoroughly clean the surfaces to be glued using isopropyl (electrical contact cleaner is my choice.) Be generous with the Shoe-Goo on the inside, but not so much that it interferes with the movement of the bellows.
R
Twin Cities Spring Ride and Barbecue
Saturday, May 18, 2013
1978 CX500 Standard - The Black Maggot -> Green Grub, Red Grub, Yellow Grub???
Mods: Daytona-style fork brace, fork boots, air fork kit, Spitfire windshield, '81 radiator and trim,
Hondaline engine guards, Ignitech CDI, blade fuse, Goldwing air shocks.
1981 GL500 Basket case -> AdvWing (Dual-sport conversion in progress)
#12
Posted 27 June 2012 - 10:24 AM
Help
