I have a cx500tc with a low idle problem. It will idle fine at <1000 rpm. Between 2000 and 3000 rpm's it acts like it is being starve of fuel, it hickup's and misses. Above 3000 rpm's it has no hickups or missing and runs fine. I have went through the fuel system, cleaned all of the screens and replace the fuel filter and had the injectors cleaned and rebuilt. There are no codes in the computer. The symptoms remain the same. It also does not seem to generate any turbo boost. I have owned two other turbos prior to this bike and it is very evident when the bike goes into boost. When I got the bike the previous owner had a clamp on the waste gate which seemed a little odd, not sure what that was all about. I removed the clamp and it did not change anything. I thought it may have a bad pb sensor, I put a new/used pb sensor on it and that did not change a thing. I am not sure where to go from here. If anyone has any suggestions it would be greatly appreciated.
